How to override auto scene with global variable?
Hi, guys.
Ive set up a simple scene to control the heating (see attached screenshot). However, i want the possibility to override it (for a set time). For example, if someone wants it hotter than 21C, they would switch the Z5 UFH relay and HC2 would override the scene for, say, 60 mins.
Ive tried creating a predefined global variable with two values: on and off. But i cant get any further! Logically, i need a new scene that switches the GV to on when someone switches the relay. Then i could simply add an if statement to the original scene (attached) so that scene only runs if GV is off.
How do i do this, and, also, how do i add the 60 min period? I would rather do this with block scenes if poss (as i dont understand LUA).
Many thanks in advance!
8 answers to this question
    Bump.
    Can anyone help?
    Yes with global variables but you will need multiple scenes
    Edited by Jamie mccrostie
    didnt read the question correctly
    No sorry i started  answering but didn’t realize you didn’t want to use Lua.
