Jeroenimo 0
Hi, since a couple of months my Fibaro HC2 is acting weird. I need to reboot the device in order to work again (the Iphone APP and scenes are not working anymore). When going the GUI I get the 503 server unavailable issue and I can only restart the services to resolve the (temporary) solution. Or just remove the box from power and connect it again. I was first blaming my ISP, but I switched providers and modems I am still having the same issue. The device also gets pretty hot. I upgraded to multiple versions in past months and tried several configuration changes, but none helped. I also set the IP address to fixed, but that also didn't help.
Before returning the device under warranty I would like to check if anyone is having any suggestions.
Thanks.
8 answers to this question
