Problems with Q2 output channel
Hi!
I have encountered a kind of weird problem with my Fibaro Double Switch 2.
It is connected according to the first picture and the physical switches on the wall is working perfectly.
The Switch 2 is connected to a Samsung Smartthings Hub, and I`m using the Samsung Smartthings apps.
As you can see from the screenshot attached there is only one switch available in the app - and this controls only the Q1 output.
I haven`t found a way to control the Output Q2 in the app, even after a tremendous amount of hours searching on Google..
Does anyone know how to control the output Q2 from the app (or if it is possible at all)?
Edited by morten-lande
