Raj 0
Hi guys,
Got an issue with fibaro rolling shutters 3 got a somfy left right motor can't calibrate the shutter to get specifics position,
I've tried to change with the timing and watt section the curtain via pc or app works properly and i got position
Force calibration all is good,
Going to switches (S1 S2) momentary switch i can not know on app the position of the blind all i can get full open full closed,
some one got a solution
