codowd 7
Hoping someone can give me a steer here.
I have a light on a Fibaro Dimmer (S1) and I have associated S2 on this dimmer to a Fibaro RGBW module. S1 and S2 on the Dimmer 2 are physically wired to a wall plate.
Switch S1 works just as expected. Also on the Web UI switch S2 works as expected. However Physical switch S2 does not work - no action whatever. Nothing recorded in the Fibaro event log.
Now I know the physical wiring is OK - when I turn on Parameter 29 on the Dimmer 2 to switch S1 and S2 then the behaviour is replicated on the opposite switch.
What am I missing?
Edited by codowdmisspelling
