Virtual Device buttons to send HTTP, please help
I try to find an easy solution to control IKEA Fyrtur for a non-coder! :)
One easy solution could be VD buttons sent to Webcore (smartthings), a webore Piston could easily be triggered by HTTP
If someone could please help, if possible for HCL (non LUA) if not please help with lua.
Here is an example of a url that works as a trigger in the webbrowser, see also picture for webcore`s own explenation as it should be sent as a POST FORM or POST JSON.
Edit:
I managed to trigger a "webhook" string to homeassistant, so using the same setup, should work for this but it is not?
POST
HTTP/1.10x0D0x0A0x0D0x0A
Edited by ryvaenge
    Also rewrite this into a VD: I have tried with different copy pastes from other VD`s to get this json sent, but do not get anywhere. (got it to work in postman)
    POST /api/services/cover/SET_COVER_POSITION HTTP/1.1
    Host: 192.168.10.254:8123
    Content-Type: application/json
    Authorization: Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJkOTg3ZmY5ZWJlYTE0N2Y3ODY4ZmI1NWFlOGJhNmIwNSIsImlhdCI6MTU3MDkzODc5NCwiZXhwIjoxODg2Mjk4Nzk0fQ.Er2siC_Zp6U5rI1jjgK7UTAhe-XGP_Vyfi0H1H0lV3k
    cache-control: no-cache
    Postman-Token: 4a59f074-84f0-47c1-9b68-d4b3a2fac87f
    {"entity_id":"group.rullegardinoest", "position":"50"}
    ------WebKitFormBoundary7MA4YWxkTrZu0gW--
    Hello Guys, do you have any working solution to control IKEA Fyrtur from HC2? (directly HC2->
    Hallo, gibt es vielleicht mittlerweile eine Lösung um Fyrtur in das HC2 zu integrieren? Gruß
