usyntax2 0
I have problem with tcpsocket request. When i send data through global cache 4999 port i get tcpsocket error code 2. Where i can get list of error code meanings?
Situation in details:
I have dscalarm module (DSC powerseries TI-100) and global cache. Home center 2 should connect to alarm module through global cache rs232 4999 port. Problem is when i integrate alarm through DSCalarm plugin then i can't see any control(zones, partitions) in interface(only in plugin configuration). So, i decided search some scripts. I found this:
https://incedo.org/~sjoholmp/Fibaro_Homecenter/LUA/VDs/HC2_DSCengine/ (latest.lua).
In this script i get:
Script error: [DEBUG] 11:31:14: Error code is: 2 Failed to communicate with IT-100 doing keep alive request!
This error shows tcpsocket error code. Maybe someone knows how to make visible alarm control in main interface(not in plugins configuration)?
