Hi... i would like to check and compare the pulse received from the universal binary sensor, in particular:
- sensor is connected to a limit switch to detect the rotation of a food feeder (every pulse is a sector of the feeder and a quantity of food)
- with a vd I would like to set a quantity of food (60 gr or 70 of 80 gr)
- at the correct time the fibaro switch turn on and the rotor start dosing the food.. one sector (one pulse) is 10 gr food
- scene has to count 6 pulses or 7 or 8 (or whatever) and once reached the required quantity turn off the switch
- between the pulses the switch has to turn off for few seconds (10 seconds) and then turn on get a pulse and turn off for other 10 seconds.. a sort of pauses between the pulses
Is there somebody able to help me?
Thank you
