For HCL and HC2
Test users are welcome!
To NOT include given device in HomeKit, mention a word "nohomekit" in device description (Disabled and Hidden devices are ignored too)
Download from here:
Edited by jack.daniels
So uhm whats the difference with using Homebridge / Fibaro:
   (which also supports HC2)
Edited by tcviper
    Well, u need another PC to host it (first of all)
    Also, its a huge application and it needs resourdes (HCL not have one)
    I have expirience with homebridge on remote PC and was not happy about it.
    I have small system, but even now there are 64 devices (logical), homebridge supports upto 100 devices and not covers most of requests
    Homebridge using polling once in X seconds, and here we have instant event feedback
    Ok sounds good.
    And a HC2 version? :)
    On 10/18/2019 at 10:38 AM, tcviper said:
    And a HC2 version?
    well, its easy to build the x86 binary, but I have no HC2 box to test it. Ill thy it later on VMWare. Need to add all features first (still not added thermostats and tamper status)
    I need some files from device in order to try it on VM
    /mnt/nvm
    /mnt/hw_data
    If someone can shere it by PM, would be great...
    I have managed to start HC2 4.560 under VMware, so here is the test sample of homekitten for HC2
    Installation:
    This should work for any new OS firmwares (4.500-4.560).
    Report the feedback here, please
    Upd: tested and works, Tar reuploaded with fixed path (bin -> sbin)
    Reuploaded fixed archive
    Installation:
    does't support locks yet?
    where i can apply this commands on my HC2?
    No locks and no thermostats yet. This is for upconing versions
    You can use the keyboard+tv (console) or SSH. Yes, You need your HC2 root password.
    There were root password read exploits for older fw versions. 4.560 - some holes were closed.
    HC2 is not like HCL:
    HCL root password is hardcoded and constant for all consoles (root HHS login id disabled, so thats normal)
    HC2 root password is stores on AVR controller and unique for every console. There r many ways to get it out or to hijack.
    Another approach is to add fibaro to mqtt bridge and to host a broker on the HC* side
    This will be usefull for connecting dashboards
    HC2 version is ready for tests as well
    • 1 year later...
