I would like to know if the devices i bought in Poland would now work in Spain? I have home center lite and a couple of wall plugs, one motion sensor, smoke detector and water detector.
The second question is would it be possible to communicate thru local wifi network in Sweden with my devices in Spain? What do i need to be able to access my home center , is the ios app enough or do i need to connect to a special server or do the home center has its own ip which is used to access the local network ?
I guess all this questions are found somewhere at this forum but as there are so many topics i do not know where to start.
Thank you for all help i can get.
best regards Sebastian
To acces you're HCL from anywere in the world.
Create an account on.
Regiter you're device there,
