gedein1785 2
Hi ,
I look to use a "smart implant " to connect an alarm system intelligently to my Zwave network ( Use light flashing for a smoke alarm)
I don't plan to use scenes but rather the "association " method
I built a test set up where the smartimplant is fed with 9v DC , input 1 (IN1) goes to momentary switch.
Goal is to light a yellow bulb when there is an contact closure on IN1 ( IN1 is configured as NO , binary input)
It is associated to a Fibaro dual relay module , output 1 ( with yellow Bulb)
Association is done in Multichannel mode:
The association does not work
Other setups using associations do work ( univ sensor with smart plugs, qubino relays with fibaro relays , fibaro dimmers between each other ...)
so , why is this one not working? what is configured wrong?
additional : what is the meaning of the "Security mode " [ in blue , top of screen ] ? is this a sign of encrypted comms ? if so , do other devices accept hte comms from the smart implant
thanks for your support
Geert
edit : question resolved . A device in security mode can not be associated to a device in non-security mode. For smart implant , the mode is defined at moment of inclusion or [adding the device]
Edited by gedein1785answer included
0 answers to this question
