knuth 29
This is not a question but a small contribution, if anyone should be interested. The task was this:
How can I control indoor ventilation to avoid temperature/humidity combinations that risk growth of mold or mildew? The first trick was to find a simple formula for this risk zone. I used a calculator in www.dpcalc.org which indicates risk/no risk for a given temp/hum combination. Testing this for realistic values for normal indoor or basement use, I found this simple linear correlation would work:
Humidity limit (%) = 91.2 - 1.184 * temp
For temp>22 the limit is set constant at 65 %. Temperature is in degrees C.
Example: If the temperature is 10 C, the relative humidity should stay below 79.4% to avoid the risk of mold growth.
Assuming you have one or several ventilation fans, and one or several temperature/humidity measurements, you can use this to start the fans when the humidity level exceeds the limit. Alternatively, you can increase the set point for a relevant heater, to increase temperature and reduce relative humidity in the room. A push warning to the owner could also be included. I have chosen to only start the ventilation fans, and I include a small LUA script to achieve this. My temperature/humidity measurements are from two Aeotec Multi6 units, but any such sensor may be used. Feel free to implement any part of this script to suit your purpose. Please share here if you use these ideas in other ways or have related ideas yourself.
16 answers to this question
