it is not possible to add favorite colors
Guest domotex
good morning everyone, I have a problem with the rgbw controllers. it is not possible to add the desired color with the plus sign. I reset the controller but it still doesn't work .. help me thank you all
12 answers to this question
Hello all,
have the same problem. Only colour programs can be configured and saved. Anybody an idea?
Guest rcschoeni
    Hello
    Today i install the 4,570 version but this problem is not fixed.
    Please Fibaro fix this Problem or giv a Solution to fix this Problem.
    It may not be that I delete favorites but cannot create new ones.
    I need my personal Favorites!
    Edited by rcschoeni
    I have the same problem. Is there a solution? Or is it just the new HC3 that is being taken care of?
    Strange, no problem overhere. Have you tried a different browser?
    what browser are you using?
    I use Firefox, IE, Edge
    Edited by treblade
    it is only possible for RGBW2 modules, a quick check of the FW4.570 \var\www\fibaro\js\classes\MainData.js confirms why:
    createRGBColor (which is called once you click on + sign in Color picker) will only work if the Device is "fgRgbControllerZw5Class", which is only true for RGBW2 module.
    The workaround is to add at least one RGBW2 module to your istallation, add there your fav colors and use them on all the other RGBW modules (as fav colors are for all modules).
    Edited by tinman
    (tinman has the answer. I do have a RGBW2 module and use Chrome)
    Thank you for help. With the RGBW2 module the favorites work, but with the RGBW2 module the programs do not work
    hehe that's right, that's Fibaro ?
    is there any way to play an own program on the RGBW2 ?
    @tinman
    Could you please post the link to get  FW4.570 files... looks like my old link doesn't work anymore.
    Hellow,
    how can i change programs if i don't have them
    /monthly_2020_02/image.png.51ede0f16276aad6ab4d28583bd945e4.png" />
    can anyone help me?
