Phantome46 0
I have an open plan kitchen and living area and currently have underfloor heating. I have a heater thermostat in the kitchen area and then one at about half way down the room for the living area.
the issue is I have a lot of glass along one side and around the corner of a wall in the form of 8 bifold door panels.
when you sit in the living area towards the window you can feel a temperature difference in the room which means the thermostat clicks off reaching the right temperature in the middle of the room before the end is warm enough.
so my thinking is can I have the temperature from the PIR sensor relay back to the heat it unit and then continue to call for heat until the temperature is reached?
how do I code for this as a scene? Please help as I’m a novice
thanks
