I have three rooms with a Dimmer 2 in each. The dimmers are activated from motion detectors in each room. While cleaning I'd like to have the lights at full output and I have set parameter 19 to 90%. When activating the toggle switch the lights will go to 90% but when the motion sensor see a motion it will activate the scene dimming the lights to 8%. Is it possible to make S1 override all scenes as long as it is on? At the moment I turn the motion sensors towards the wall so they aren't activated but that is no sophisticated solution!
12 answers to this question
hi
you can do this by creating a variable eg motion with 2 values on and off
amend the scene to say that if motion is detected and the variable motion is on then turn lights to 8%
on the dimmer 2 change parameter 28 to 'functionaly activated' this enables scene activation.
then create a new scene that changes the motion variable from 'on' to 'off' and vice versa by scene activation.
the codes that you need are:
toggle switch S1
10 is when OFF to ON
11 is when On to OFF
14 is when 2 x click (ie on/off very quickly)
hope this helps
11 hours ago, morpheus75 said:
hi
toggle switch S1
hope this helps
(c) by Sank
%% properties
467 sceneActivation
%% events
%% globals
function dump(o)
   if type(o) == 'table' then
      local s = '{ '
      for k,v in pairs(o) do
         if type(k) ~= 'number' then k = '"'..k..'"' end
         s = s .. '['..k..'] = ' .. dump(v) .. ','
      return s .. '} '
   else
      return tostring(o)
--   SCENE ACTIVATED BY DIMMER SWITCH  --
-- Making sure that only one instance of the scene is running.
if (fibaro:countScenes() > 1) then
  fibaro:abort();
-- setup some local variables
-- print(dump(startSource))
local deBug = true;
-- MAIN CODE ---------------------------------------------------------
if startSource['type'] == "property" then
  local devID = tonumber(startSource["deviceID"])
  local ButtonPressed = fibaro:getValue(devID, "sceneActivation")
  if     ( tonumber(ButtonPressed) == 16) then -- pressed 1 click
        local state = tonumber(fibaro:getValue(devID, "value"))
        local current = fibaro:getGlobal("DutyLighting")
        if state > 0 then
            if current == "ON" then
                fibaro:setGlobal("DutyLighting", "AUTO")
            else
                fibaro:setGlobal("DutyLighting", "OFF")
          else
            fibaro:setGlobal("DutyLighting", "ON")
        if deBug then fibaro:debug("1 click") end;
  elseif ( tonumber(ButtonPressed) == 14) then -- pressed 2 clicks
          --fibaro:startScene(7); -- run scene to turn off garden lights
        if deBug then fibaro:debug("2 click") end;
  elseif ( tonumber(ButtonPressed) == 15) then -- pressed 3 clicks
        if deBug then fibaro:debug("3 click") end;
  elseif ( tonumber(ButtonPressed) == 12) then -- pressed hold down
        if deBug then fibaro:debug("holding down") end;
else
      fibaro:debug("Scene activated manually so nothing to do");
sorry, attaching code/files doesn't work anymore
@T.Konopka
    Thank you both for your promt response! As I am new to Fibaro and haven't used LUA code earlier I will dig into creating this variable to use together with graphic blocks.
    It's a learning process made easier with the help of you guys!
    1 hour ago, ollehlund said:
    graphic blocks.
    you can't use sceneActivation in blocks. no functionality here.
    As long as sceneActivation is enabled for that dimmer then you can choose that function from graphical block scene
    good to know. you right! I never used blocks, if honesty :)
    I need to use for clients who have HCL and not HC2. We are all always learning from each other. The power of forums!
    Sorry for my silly questions but I'm totaly new to this! I have the sceneActivation enabled for the dimmer and now I can choose the function. But what value should I insert in the green block "Scene Activation"?
    toggle switch S1
    1 hour ago, morpheus75 said:
    toggle switch S1
    btw has com.fibaro.FGD212 another values :(
    Seems to be working now! Thanks a lot!
    here is the full list of scena Activation codes for the Dimmer 2 module:
    Momentary switches
    SCENE ID: S1 input
    16 : 1 x click
    14 : 2 x click
     - : 3 x click
    12 : hold
    13 : release
    SCENE ID: S2 input
    26 : 1 x click
    24 : 2 x click
    25 : 3 x click
    22 : hold
    23 : release
    Toggle switches
    SCENE ID: S1 input
    10 : OFF to ON
    11 : ON to OFF
    14 : 2 x click
     - : 3 x click
    SCENE ID: S2 input
    20 : OFF to ON
    21 : ON to OFF
    24 : 2 x click
    25 : 3 x click
    Roller blinds switches
    SCENE ID: S1 input
    10 : turn ON (1 x click)
    13 : release
    14 : 2 x click
     - : 3 x click
    17 : brightening
    SCENE ID: S2 input
    11 : turn OFF (1 x click)
    13 : release
    14 : 2 x click
    15 : 3 x click
    18 : dimming
    Edited by morpheus75
    update
