Danalock as Trigger
Hi to all Danalock User and Lua Cracks,
The task seems simple to me. Switch on light (controlled by Walli Switch) for 30 sec when danalock goes to open.
But I'm not able to use Danalock as trigger anyway, exept using IFTTT.
with IFTTT (MagicScene) Im able to switch on the light but not able to switch off the light.
I'm not very common witch IFTTT more over i hate to use it. But why doesn't BlockScenes work at all with danalock?
Creating a LuaScene from scratch gives me
775 AccessControlEvent Manual Unlock
where 775 is the device ID. But what should this mean to me?
if AccessControlEvent Manual Unlock = true ? than .......
Could some one help me out. I even didn't find any luacode with a danalock involved.
Hopefully
Gerhard
Edited by ggoetz56
6 answers to this question
Hm, it works for me. I have many scenes which start by triggering danalock with either unlock or lock. I only have a problem if batteries are a bit bad and danalock doesn't report state correctly. Other than that, scenes work ok. I didn't use LUA, block scenes seem to do the work. Maybe there's some other problem?
Hopefully
Gerhard
Try to recalibrate it....
    Thanks for your response!
    Some more test and calibration. No change. I can choose Danalock in the trigger section of blocksceens. So I'm not the only one with that issue it seems this is not a general issue.
    Does someone use luacode with Danalock?
    hey, you should try
    775 value
    as trigger, in the header of you LUA scene.
    value is "1" or "0"
    Best.
    To usue it in lua.
    just use this below
    Edited by sonnyboy
    Hi All!
    I have a big problem with Danalock v3 locks at once. I have lua codes, they can open two locks. But z-wave communication is instable. Once HC2 opens only one lock, or opens the two locks but not close them as the source code contains it.
    When Danalock's status changes HC2 does not sense it. Why?
    I put a Wall plug next to them. Nothing have changed.
    I started to run a Z-Wave network discovery, but i has not been better.
    Does anyone know the solution?
    Thanks!
