I would like to smartify my central heating system.
I thought about the Fibaro smart implant but I am not sure if and how I should realize this. So I hope for some help on your site :).
I have the following temperatur controller:
PTFP 100-P0537
Linked here:
http://www.gazdafielectronic.hu/main.php?evid=b2JqZWt0dW09a2F0YWxvZ3VzJmZ1bmtjaW89Q3NhdG9sYXNMZXRvbHQmaWQ9MzU3Mg==
There is no room heating connected, only the heating control basically this controler would be equivalent  PTF 100-P0500.
Is there a chance to use the FIBARO implant as a substitute for the controler?
How and what I have to do?
Best,
Paul
Fibaro smart implant doesn't activate outputs based on temperature. (As far as I know)
Yes, you can do it, but
1. you need some relay to control smart implant INPUT, or directly to control your heating system with this relay (Preffered option)
2.you need to create a scene, which based on temperature value will switch the relay.
May I suggest to simplify it... use motions sensor with temperature measurements and control  Z-wave plug (relay).
Edited by cag014
