rickydehaas 4
Hi All,
Desperately need your help with the following:
I'm trying to accomplish to send a pushmessage to my in-wall dashboards when motion is detected. After motion is detected the scene needs to check every 10 min if the motions lastBreached is lower then 30 min and send the pushmesssge again until lastBreached is more then 30 min
This is what i have so far:
%% properties
203 value
%% weather
%% events
%% globals
USBWKScreen
if (fibaro:countScenes() >1)
then
fibaro:abort();
-- Local
local hc=fibaro;
local StartSource=hc:getSourceTrigger();
local iosDeviceID = {43}; -- inwall dashboards
local motionID = {203}; -- PIR sensors
local movement = 600; -- 10 min
local screen = "USBWKScreen"; -- variabele
local screenMapping = {On="Aan", Off="Uit"};
-- Send notification to devices
function setScreenOn()
if(#iosDeviceID > 0)
then
for i = 1, #iosDeviceID do
hc:call(iosDeviceID, "sendPush", "ScreenOn");
hc:debug("Message send to device - "..iosDeviceID);
else
hc:debug(" No devices found");
-- Main
if(hc:getGlobalValue(screen)==screenMapping.On)
then
for i=1,#motionID do
if ( (tonumber(os.time()) - tonumber(fibaro:getValue(motionID, "lastBreached"))) < tonumber(movement) )
then
setScreenOn();
else
hc:debug("Scene runned")
else
hc:debug("Scene runned"))
Thanks in advance!
Edited by rickydehaas5 answers to this question
