Two dimmers, one SX or common
Is it possible to use the sx or common from one dimmer to also use with another dimmer? Or maybe wire them together? I want to use a single 3 button switch with common connection to give signal to two different fibaro dimmers.
Yes, you can use SX with Dimmer No. 1 to control Dimmer No. 2 Both dimmers must be powered from the same source
    Ok! Thank you for the answer. I was hoping this would be the solution to my lighting problem ?
