turnoff lights when multiple motion sensors in a room aren't breached for a few minutes.
Hi all,
I noticed the large amount of smart light-scenes in this forum, but i didn't find the answer i was looking for.
I created a scene which checks (runs every 5 min by mainloop from @Sankotronic) multiple motion sensor if they aren't breached for (lets say) 30 minutes. When true then all lights in the same room as the motionsensor will turn off.
Problem is that some rooms have multiple motion sensors and currently if 1 of the sensors aren't breached for 30 min, the lights in that room will be turned off,  but what i'm lookinfg for is when all sensors in 1 room aren't breached for 30 minutes, then the lights are turned off.
Current scene:
%% properties
%% weather
%% events
%% globals
if (fibaro:countScenes() > 1) then fibaro:abort() end;
local hc=fibaro
-- Locals
local lightID = {191, 33, 57, 116}
local motionID = {79, 102, 107, 50, 203, 194}
local movementMax = 30 -- in minutes
local motionRoom = "Null"
-- Mainscene
if(#motionID > 0)
   then
   for i=1,#motionID do
      if ( (tonumber(os.time()) - tonumber(hc:getValue(motionID, "lastBreached"))) >= (tonumber(movementMax)*60) )
         then
         motionRoom = hc:getRoomNameByDeviceID(motionID)
         if(#lightID > 0)
            then
            for z=1,#lightID do
               if (hc:getRoomNameByDeviceID(lightID[z])==motionRoom
               and tonumber(hc:getValue(lightID[z], "value")) > 0)
                  then
                  hc:call(lightID[z], "turnOff");
                  hc:debug("turned off light - " ..hc:getName(lightID[z]).." ("..hc:getRoomNameByDeviceID(lightID[z])..")")
Thanks in advance!
Rick
7 answers to this question
I have tried as well to solve similar issues with Lua, but I'm not s SW person.
May I suggest take a look on All-in-One Scene by @cag014 (in download center) it a matter of seconds to do what you need.
Edited by AR27690
...and with
the rule look like
the old behaviour, if one sensor is safe for 30min, would have the last rule look like
@rickydehaas you forgot to add to props at header motions id's
    14 minutes ago, jgab said:
    ...and with
    the rule look like
    Thanks, Correct me if i’m wrong, but this won’t fix my problem: Turning off the lights in 1 room when both motion sensors havent been breached in 30 min
     Thanks for looking into it @10der. The scene will be runned every 5 min (scheduled by another scene).
    problem i’m facing with my script is that currently lights in 1 room will be turned off, when 1 of multiple sensors is not breached in 30 min. Because i’m using multiple sensors in 1 room, i need to rewrite the script that lights in a single room only will be turned off when ALL motion sensors in that room ar not breached in 30 min.
    if motionID are the sensors in the room in question, trueFor(00:30,motionID:safe) returns true if all sensors are safe for 30min , which is what you wanted, or?
    If motionID is a list of more sensors than the ones in the room you want to check, the rule becomes bit more complex because you have to filter per room. However, I would recommend to
    have a list of sensors per room.
    2 minutes ago, jgab said:
    if montionID are the sensors in the room in question, trueFor(00:30,motionID:safe) returns true if all sensors are safe for 30min , which is what you wanted, or?
    have a list of sensor per room.
    @jgabThe second/last behaviour your mentioned. The scene uses multiple lights (lightID) and sensors (motionID) available in multiple rooms. The goal was to write a simple scene for a few selected lights in multiple rooms and turn them off when there is no motion in the room for a specific light for more then 30 min... when i was writing the scene i forgot that some rooms have multiple sensors, which made it more complex.
    Will check eventrunner in the next days if it will fit my needs. Thanks for looking into it!
    @jgabThanks,
    I will implement that too.
    Not to switch light off but going into very dimmed setting. Since we have all led and HUE lamps it will not cost so much to let them light on small Wattage.
    The EVENT RUNNER is great and simple to code.
    //Sjakie
