Scene converted from blocks to LUA stopped working
Hello
Can someone tell why scene #1 works but not scene #2? Both are made as block scenes and both worked but after converting them to LUA #2 stopped working.
I tried to add this to make sure I didn´t have to many instances without luck.
Scene #1 working
Scene #2 not working
10 answers to this question
Strange, have copied your scene and it works (with different devices IDs)
Instead of having endless block scene you could try to use All-in-One Scene... as you wish
Edited by cag014
May I ask you what is device number 13 in your system (switch, sensor?)
    13 is a switch and 155 is a dimmer, both Fibaro
    /monthly_2019_11/image.png.f5aef8d468b0c3e41da9e1ee5f420a77.png" />
    155 is Toalett: Toa spotlights
    Honestly, I don't know how your first scene works, it shouldn't.
    But it's doesn't matter... I think you have change another line
    was  end, 1800000)   to   end, 10000)   , right?
    You must set this line at least for the same time period, deviceLastModification0) >= 1800  that you're looking for, otherwise the scene stops before that (in your case 10000 mSec. or 10 sec.)
    Please change the line back to ( 30 minutes)
    end, 1800000)
    in both scenes and it should work.
    By the way there is no reason to limit the scene to one instance. It should be 2 instances as created by block scene.
    But it's not makes big different.
    Please let me know it it works?
    Edited by cag014
    No, I haven't changed anything but the first lines about not starting another instance if one is already running and the 10000 is set in both scene ? but I have now removed my extra lines and changed the 10000 line to 1800000.
    Edited by storskogen
    Sorry, did a copy-paste error. Pasted the same scene twice. It should be two different scenes. But also found that it had 13 and not 155 in this line.
    My memory must be failing me because I can´t remember that I wrote this scene (copy, paset, change), maybe if I copied the scene as a block, changed the "turn off-device" to 155 but not the initiating device.
    I now remember that I have had similar problems with another device (1x3kw switch) when switching to LUA. I will investigate that later but for this scene i changed to 1800000 and the line above to 155. Keeping the "countScenes".
    Great job, so, everything works as designed?
    No, it did not :( I will erase the LUA scene and create a new blockscene for now.
    No, I haven´t tried that but I was thinking about starting with a new LUA scene and write everything from scratch, no conversion.
    I have thought about a all-in-one-scene but I don´t know how to do that yet and I don´t have the time to learn that right now.
    I made a last try, I copied the working scene and changed the device id and now its working :) why didn´t I do that before ?
    Thank you :)
