I am new to the forum but hoping someone may be able to help with a problem a have with HC2 & Motion Sensors FGMS-001
I have tried adding these sensors but all I have succeeded in doing is getting them to blink randomly
pressed the add button on the back of the box & then clicked B 3 times rapidly, blue light came on but non of them would link one was second hand through ebay but changed the batteries but non of the three of them are attaching to HC2.
Is there any tips/help someone could give?
Second hand... could be the devices still "paired" to old system.
Please follow instructions of the sensors for factory reset and then try to include
Edited by cag014
Try in your browser to remove the devices first . That will reset them to factory settings.
/monthly_2019_11/image.png.1200bc7b84b6ed52255fc223d37ad1af.png" />
After that procedure, try to add then again:
Success!
@Bodyart
Are you sure? If it was "paired" to other system, will be set to factory reset?
Nice to know if it works!
1 minute ago, cag014 said:
@Bodyart
This i've learned from Master Peter :-D
/monthly_2019_11/image.png.627123469368ca5336ea4678b5a81850.png" />
Edited by cag014
Second hand
Are they the right frequency to match your controller?
Are they for a different region?
Edited by Jamie mccrostie
After triple click just mount the cover.
Often device doesn't react until the cover is closed.
"any controller can remove/reset any device at any time. Just remove it as any other device"
Also a good test to see if they are the same frequency: if the controller says "removed" it was able to hear and reset the device. If it doesn't, in rare cases, your HC controller might need a reboot. Otherwise you have eg EU controller and US frequency.
