bundi 0
Hello guys,
I would like to use on of my FGWP102 wall plugs as a zwave repeater for Danfoss lc13 trv. Are they compatible? Can traffic from lc13 be routed through wall plug?
If that's the case, is following procedure correct or not?
I'm planning to temporary move controller closer to trv to successfully include lc13 to network and then move home center back to it's original position.
Then I'll plug in the same room as a have lc13 the wall plug. Will trv automatically connect to wall plug, or has to be done some configuration?
One potential issue I see that trv is communicating with home center in its original position, but probably have a weak signal, because I got e5 error on trv and some other issues.
So another question is, will lc13 connect to wall plug, even if it sees home center...?
6 answers to this question
