HC2>Configuration>General>LED brightness:
Hi!
Can anyone, pease, explain me what is the use for HC2>Configuration>General>LED brightness:?
I can't find description about that option on HC2 manual.
I changed to different values, but my lux measurements don't indicate changes on lights brightness.
Thanks!
8 answers to this question
hi @puertobahia,
It's the LEDs at the homecenter case.
And the HC forgets the setting on each restart.
BR - kro
See at configuration panel
Edited by cag014
    Thank you guys!
    On 11/14/2019 at 1:56 PM, kroeatschge said:
    hi @puertobahia,
    BR - kro
    Is there a way to lower the brightness with Lua? It is quite annoying that the HC2 all the time forgets the setting after reboot
    Yes,
    api.put ('/settings/led', {brightness=15})
    The number is a percentage of LED light brightness.
    15 minutes ago, cag014 said:
    Yes,
    Top, thanks very much
    Could fibaro guys just fix this bug of not saving  the brightness setting permanently. Lua scripts solving this seem to be a little wrong way.
    @savilmik,
    first I also didn't like it. Now I got used to it.
    It can even be useful: when the LEDs are at max brightness I know there was a power outage or unexpected restart of the HC2 ?
