Virtual Device showing actual temperature but also the highest and lowest in the last 24 hours
I'm trying to get the Virtual device to compare and update a highest and lowest value, but not succeding.
fibaro:call(340, "setProperty", "ui.Label1.value", '\"' .. fibaro:getValue(27, "value") .. '\"')
if (("ui.Label1.value") > ("ui.Label2.value")) then
    fibaro:call(340, "setProperty", "ui.Label2.value", '\"' .. fibaro:getValue(27, "value") .. '\"')
if ("ui.Label1.value" < "ui.Label3.value") then
      fibaro:call(340, "setProperty", "ui.Label3.value", '\"' .. fibaro:getValue(27, "value") .. '\"')
VD can’t save own states in LUA cuz lopped by outside
but you can save temperature in global param or in two values or in single value in JSON
