Meuja 0
I have a Fibaro Walli Switch that I'm using in a 2 way switching (like diagram 3 in the Walli Switch manual). I made it works, but not according to the documentation.
It is set in single switch config and I set parameter 20 to value 3 for multiway switching (reverse state between Q1 & Q2), but it doesn't work.
If I set value 1 to parameter 20, it works as desired (Q1 on = Q2 off, Q1 off = Q2 on) for manual switch operation.
But when I change Q1 state over Z-wave network (i.e Q1 on command), It change switch 1 state but I don't get switch 2 updated with reverse state from switch 1.
I was thinking to send Q1 on and Q2 off, to preserve reverse state, but in single mode config I have only instance 1 controlling switch 1, I cannot make interaction on Q2.
So it may be a bug with parameter 20. But my concern is how to command the switch without loosing reverse state?
