knuth 29
My Fibaro HC2 is connected to a 4G router for external (WAN) communication. The mobile network coverage is variable, and the external signal some times fails. In a LUA scene I want to check that my external WAN connection is not down. I assume that the LAN and its router are working normally, so I need to check against an external name server (DNS) or something. What would be the easiest way to implement this in LUA? I have looked at the request(url, options, succes, error) function, thinking that this maybe can return an error function which I can use as an indicator. But I am not sure how to set it up. Am I on the right track? Any ready-made solutions for this situation out there? Or any good ideas?
8 answers to this question
