Fibaro HC2 + DSC alarm
Hello all !
I had Vera Edge but I decided to change it to Fibaro HC2. One of most important things for me is the integration with my DSC alarm. I do it well with vera but I can not do it with Fibaro !
Configuring the native DSC plugin it doesnt work.
I have IT150 board and aslo Envisalink 4 (the one that vera use)
My alarm is a power DSC 1864.
Can you help me? Thank you in advance
Marcelo.
4 answers to this question
On 11/19/2019 at 7:04 AM, emeceuy said:
Hello all !
Marcelo.
Take a look at this thread, that’s a nice DSC integration
Hello all !
Marcelo.
You can try this and see if you like it.
If you like it, it would be nice if you rated it :)
And there is an update on the way. Probably before christmas.
/Peo
I have a question about this intergration.
I have added it to my Fibaro Home Center and I can see the Motion sensors reporting motion and all other functions are active, but the sensors(zone) names are incorrect.
Basicly they are still default names. For example, ZPIRHallway and so on...
What am I doing wrong?
You have not read the documentation PDF ?
You fix this as a part of the setup by changing the zones multi variable. Amount of zones and the names you want. There are more to adjust. User names for example...
I suggest you go through the PDF
PS
And if you after the final configuration like it, please rate it at Fibaro marketplace
Regards
/Peo
