Heat controller reacts slowly
Did you have a look at parameter 2
rapid or moderate response?
    All values are standard. What surprises me is that there are different points under parameter 2.
    See attachments.
    Had the same problem,
    took me some struggle to get this solved.
    Brought the Home center near the Heat controller.
    Made sure they are on the same firmware 4.5
    Did soft cofiguration. solved one problem.
    One of them I had to exclude.reboot the home center, Factory reset of the heat controller, include again.
    I made sure they fully charged.
    Also that the external temp. sensor was connected before I started.
    Edited by Flash
