PeterK 0
I'm using the HC2 with heatit z-trm2 thermostats for electric underfloor heating.
These thermostats (same as many others) have two temperature sensors, the air sensor and the floor sensor.
Unfotunately the Temperature panel shows the average value from both sensors which basically makes no sense as important is only the air temperature.
Is there any way to show only the air temperature in the temperature panel?
Thank you.
Peter
