hi
Why Fibaro cant control products connected via Wi-Fi like example wall plug TP-Link or others?
5 answers to this question
Hi @fingusio,
It can. You need API to integrate it. Many integration on Fibaro marketplace (
) are Wi-Fi devices.
    i dont want API integration (i dont know how to programming) I want normal integrated
    Even with normal integration an API is needed, that is what @jakub.jezek meant. If the manufacturer opens the API, everyone can program it, if not only the manufacturer can do it himself or ask FIBARO to do it.
    Like @pnutp0wer said. You need it even on basics.
    Even D-Link gateway uses API to control D-Link wall plugs.
    No true, Smarthing Hub have integrated it without any programming ....
