lua change value alarmExclude
Hi, I have to change in lua code the
in
How I can do?
I tried different solutions but no one worked
Thank's
5 answers to this question
    Hey guys! No one answers? ?
    Yo can not change property value by fibaro:call(). It works for ACTION only
    May I ask you, why you change it by Lua? Usually this done by device configuration and not by code!!!!
    In any case here is the code to do it. (change "local id" to your real device ID)
    Please note, if device is battery powered it will wait for device wakeup to update parameters. (You can manually to wakeup device).
    Edited by cag014
    Hi cag014,
    the answer to your question is that I often have to temporarily exclude zones and I must have the possibility to do so from the app
    I've execute your code but the properties.alarmExclude not changed even after wakeup
    This my code:
    Result:
    Code Check:
    Result:
    Can you help me?
    Thank's a lot
    Edited by zcris71
    The right code is:
    Thank you cag014 for the inspiration you gave me to solve the problem
    Have a nice day!
    "device" parameter is a table,so in order to print it out use:
    fibaro:debug(json.encode(device))
    or just print parameter that you need
    fibaro:debug(device.properties.alarmExclude)
    Is it works for you?
    BTW: to verify your changes just enter in browser
    http://hc2/api/devices/ID
    Change hc2 to your IP address and ID to your device ID number (something like that)
    http://192.168.1.100/api/devices/394
    Edited by cag014
