Marcs 1
Hello
Reset der intercom
To reset the device directly:
1. Press and hold the ring and the button at the same time for about 10 seconds.
2. Release both when the device glows in red.
3. Enter the last 8 digits of serial number using the rotating ring. Confirm each
number with a short press of the ring.
4. Entering correct serial number will be confirmed by glowing in green and
restarting.
unfortunately this is not possible with me
I press the ring and then the button for 10 seconds.
then 2 times the numbers look green and the key glows green .
now i can only enter the last 4 digits of serial numbers
is then actuated by green left of the numbers.
but unfortunately does not happen, no restart makes itself
this is also a possibility
