julesmartens 0
Hi
I'm trying to create an alarm via several scenes. I want to cleanup the code I have so far. This by using simple function(s).
Anybody suggestions?
I found some advanced code in existing code which is too complex. I have very limited coding experience and without some comments I cannot exactly tell what the code is doing.
So please add some comments in the code to explain what it does.
my alarm:
I have a scene that checks presence via GPS, wifi and iFTTT . If nobody home it will switch a global to armed.
I have a seperate scene to actually arm the devices I need to arm, this I'd like to cleanup using a function. If I understand the example of a function, I can reuse it elsewhere (hopefully ;-)).
if( fibaro:getGlobalValue("AlarmMode") == "FullAlarm" and
fibaro:getGlobalValue("AlarmState") == "Armed" )then
-- Alarm warning LED
local PIRState = fibaro:getValue(369, "armed")
if( PIRState == "0") then
Debug(true, "Blue", " pre-alert LED notification started")
fibaro:call(133, "startProgram", "116"); -- alarm was not on yet, notify user via led that arming process will start
fibaro:sleep(10*1000);
else
Debug(true, "LightBlue", " NO pre-alert LED notification ")
-- start arming process
fibaro:call(133, "startProgram", "214"); -- notify user by led alarm is armed.
fibaro:call(PIR1, "setArmed", "1");
fibaro:call(PIR2, "setArmed", "1");
fibaro:call(PIR3, "setArmed", "1");
fibaro:call(PIR4, "setArmed", "1");
fibaro:call(PIR5, "setArmed", "1");
fibaro:call(PIR6, "setArmed", "1");
fibaro:call(PIR7, "setArmed", "1");
fibaro:call(DW1, "setArmed", "1");
fibaro:call(DW2, "setArmed", "1");
fibaro:call(DW3, "setArmed", "1");
fibaro:call(DW4, "setArmed", "1");
fibaro:sleep(250);
local PIRState = fibaro:getValue(PIR1, "Value")
Debug(true, "Orange", " All PIR and Door sensors armed")
--Debug(true, "LightGreen", " AlarmMode has value: "..fibaro:getGlobalValue("AlarmMode"))
--Debug(true, "LightGreen", " AlarmState has value: "..fibaro:getGlobalValue("AlarmState"))
thanks!
grtz
