Broadlink ideas
Hi!
I have obsession :) intergrate broadlink device in HC2.
so, lets go
1) so. we have opensource database devices with codes for broadlink (attached)
we can't store this database as is cuz Fibaro disable all file system operation.
so, find by serach in file device for what ypu have play to use (for example as for me codes\climate\1682.json
new trying converting this file to LUA code
(JSON2LUA.LUA)
voila!
so, now add some useful feature
now we can find broadlink code by  mnemonic
yay!!!!!
but for sending command to broadlink device we should convert base54 code to hex format.
ok let add another two functions
good!
so., now we can scene for device (why scene? ok.let's go).
if you have, for example 3 Lg Tv in your house and 3 broadlink as well you can use single scene for control 3 tvs passing to scene brodlink VD + command.
in attach full example scene for LG TV broadlink device router
12 answers to this question
    Hi!
    now create broadlink VD device what used broadlink scene router above.
    in attach simple VD for connecting VD to your broadlink
    DISCLAMER :  VD can't works without your local php /web server.
    Quote
    @T.Konopka I can donate out of pocket 50$ FIBARO company for opening 1 (one) simple function
    cuz i cant implement crypt / decrypt functions for aes-128-cbc on pure LUA.
    Now, back to the subject at hand.
    impoert attached VD
    modify some lines:
    please DO NOT change anything else. only 3 lines.
    1st line local http server name / address
    2nd line ocal http server port (usually 80)
    3d - path wheere you save php file with php emcrypt / decrypt functions
    so noiw we can change VD params
    /monthly_2019_12/image.png.804449ff138aeb37c04e09a6c1dd9e5d.png" />
    IP Addrress = start IP address for your physical device
    TCP Port 10039 - Code for RM3 Mini
    list here
    send  command
    fibaro:startScene(221, {"1543", "on"})
    I starting test your solution but ...
    in place of mac address it's display VD ID :-(
    I founded where is the problem. Is in authorization, if RM3 is paired with new Broadlink app for android they block use any external access (any python projects not work). To resolve this it's need to remove RM3 from new app (when RM3 still connected to reconfigure it and reset). After this you need add RM3 to old e-remote app. After this they work with any python projects and your too. Normal reset by button without remove before from new Broadlink app not work. I will check by sniffer what this app change in RM3 on "inclusion" and "exclusion"  but if I have time at end of December.
    After added to new app:
    After return to e-control:
    Wow. I never used application from broadlonk. More than never saw and do not know how working this app ;)
    but thank you ;)
    just got from alieexpress a new brand Broadlink RM Pro+
    /monthly_2019_12/image.png.04957fdff23e0bffc2b82794d4b7b075.png" />
    works like a charm.
    now I want to pay money for native aes-128-cbc for LUA :(
    I revived to today RM Pro from same source. :-) With IR code work fiine, I start tested wirh RF with small problems (only ON commands works in the moment) bu my wife ask me.... to go bed....
    as I can see no issues with RF commands.
    You'd do well to know your place, weakling! :D
    current broadlink implementation
    [VD broadlink]  (id 1543)
    [SCENE adapter for device AC] (id 221)
    [SCENE adapter for device LG] (id 222)
    ...N
    [SCENE adapter for device Garage Gate] (id 224)
    so, caller ask adpater for device (LG TV / air conditioner / SonOff RF / etc) run command
    where 221 is adapter for device (unit)
    so, 221 scene get "off" parameter get binary code for device and call physical device (VD 1543) send this command to device (unit) for turing ""off"
    run command on physical device VD 1543 via adapter 221 (AC) command is heating with auto fan (mode) set temerature 28
    Hi @10der,
    Can you more explain how to install this VD into HC2.
    I have an Broadlink RM pro.
    Thx M8.
    @FonsBrand no how. it's not VD it's not for HC2.
    but you can ask @drboss adopt this QA for HC VD for the beer.
    For next 3-4 weeks i'm very busy in work and now I use for BL node-red. For this reasons I will start test the converted QA (today I only extracted lua from QA file) on beginning of September. When all will okey I will put it on forum
