Flood Sensor, where to drill?
jriker1
So I just got a new flood sensor from Fibaro.  Want to put in a wired connection.  Looking at the internals have a couple questions hopefully someone can answer:
1. Can the electronics be removed to make things safer?  Almost looks like it was glued down.
2. Where to drill.  The area in the front under where the top connects to the bottom is covered with foam that looks like it's also glued down.  That area looks like where you would drill.  See picture I found and attached.  Looks like they ripped away part of the foam or something?
Thanks.
JR
