Thanks guys for the answers. I am trying to use email push. I even set a basic scene just to send a push email when I run  it. For a test. But nothing. I have been using this in my scene since  day one and they have always worked. I’m not sure when the stopped. What is odd a few hours later I got 2 or so of the ones I was testing. But not all.
To be clear I I’m getting an app notifications. But no one else is. I’m have both apps installed but on really use the old one. Just can’t get into the new one.
Running 4.570. Firmware. Thanks.
On 1/26/2020 at 1:32 PM, Sankotronic said:
Hi @timothydalton ,
I never used this option from device settings because except turning on or off sending notification I have no other control. For that I have made one VD to turn on/off sending push notification if status of the sensor changes and scene that is triggered by that change and send push notification. If check of door/window sensors status change is turned off then it is still possible to get popup notification with the list of opened doors/windows when scene is manually started
You can find that solution here:
Nice solution. I will try to implement it during the weekend. This kind of restrictions exclusive to the super user is annoying (like access to Alexa/Google Assistant)
Edited by timothydalton
