Guest jodohl
Hi!
I am searching for a solution to the following challenge:
I am regulation the heating in my house by Heating Panel. To override the scheduled daytime lowering on weekdays (when e.g. working from home), I have borrowed a virtual device LUA code that works well. It is basically a VD with three buttons, for "Schedule", "Holiday" and "Home" respectively.
This code will however only accept one single override temperatur for all zones. I want my bathrooms at a higher temperature.
It must certainly be possible to amend the LUA code to achieve this. I have tried to manipulate the LUA code by adding duplicates og the core subroutine with changed variables for the zone ID in question, but the code will not run. Not very surprising, since my understanding of LUA is very limited.
Is there anyone out there with better LUA competence who could propose a solution?
The code for the "Home" VD button is given below. My bathrooms are Zone 204, which I want to stay on 24C, not the common 22C temperature.
local zoneIds = {22,23,33,47,204} -- En komma separeret liste med de Zoneid du ønsker at opdatere
local target = 22-- Din target temperatur. 0 = vacation disabled
local HC2 = Net.FHttp("127.0.0.1",11111)
local function updateZone(id)
local response ,status, errorCode = HC2:GET("/api/panels/heating/"..id)
local jsonTable = false
if (status == "200") then
jsonTable = json.decode(response)
if (jsonTable ~= false) then
jsonTable.properties.vacationTemperature = target
HC2:PUT("/api/panels/heating/"..id, json.encode(jsonTable))
return true
return false
for n, zoneId in ipairs(zoneIds) do
if (updateZone(zoneId)) then
fibaro:debug("Updated Zone "..zoneId);
else
fibaro:debug("Failed to Update Zone "..zoneId);
