Fibaro motion sensor (FGMS-001) issue - green LED always on
Bcatt
I recently connected a FGMS-001 from Fibaro to my home automation setup (using Vera Plus). The aim was to have it automatically lower to window blinds when the lux falls below a certain level, and automatically raise them when motion was detected in the morning. Using Altui & Thingspeak I also logged the lux & temperature values.
The sensor worked fine for 2 weeks, however 1 night I noticed the lux levels were at 1700 instead of 0. I went to check and noticed that the sensor was fully green continuously. I’ve since done a factory reset, excluded it from the network & re-added it several times, so far with no luck.
Currently it’s not included to my z-wave network and still glowing green: according to the manual this means the sensor communicates directly with the main controller, however it should only do that in z-wave range tester mode - which it is not in as far as I can tell.
Has anyone had this issue & found a solution? Is it Vera related?
Hi @Bcatt,
i don't have a solution, but you coul'd try following the manual to wake up the device, or to activate the menu, just to check the device it's self...
Replace the battery
  • On 12/10/2019 at 11:01 PM, cag014 said:
    Replace the battery
    Tried that, no luck: still lighting up green and not dimming anymore.
    On 12/10/2019 at 8:01 PM, Bodyart said:
    Hi @Bcatt,
    The motion sensor seems to work fine: I can go through the menu, do the range test, reset the device, ...
    EDIT: just to give the latest information, I checked all parameters defined in the manual and they all have the default values as listed there. I tried disabling the LED entirely with parameter 80, but no change: even without adding it to my z-wave network the sensor lights up green all the time. Faulty sensor and should send back / warranty?
    Edited by Bcatt
    Updated information
