Nobokazu 0
Hi can you help with device handler for single relay fgs 212 for samsung smart thing please. I tried ready device handler for dimer and from samsung forum but not working.
that what i use now but not work perfect for me.
* Fibaro Single Relay (FGS-212)
* v.0.0.1
metadata {
definition (name: "Fibaro Single Relay FGS-212 2", namespace: "JoneLura", author: "Jone Lura", mnmn: "SmartThings", vid:"generic-relay") {
capability "Switch"
capability "Button"
capability "Configuration"
capability "Health Check"
capability "Refresh"
command "reset"
fingerprint deviceId: "0x1001", inClusters:"0x20, 0x25, 0x27, 0x60, 0x70, 0x72, 0x73, 0x7A, 0x85, 0x86, 0x8E"
tiles (scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 3, height: 4){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.on", backgroundColor: "#ffffff", nextState:"turningOn"
attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.off", backgroundColor: "#00a0dc", nextState:"turningOff"
tileAttribute("device.multiStatus", key:"SECONDARY_CONTROL") {
attributeState("multiStatus", label:'${currentValue}')
main(["switch"])
details(["switch"])
preferences {
input (
title: "Fibaro Single Relay FGS-212 manual",
description: "Tap to view the manual.",
image: "http://manuals.fibaro.com/wp-content/uploads/2016/08/switch2_icon.jpg",
url: "https://manuals.fibaro.com/content/manuals/en/FGS-212/FGS-212-EN-A-v1.1.pdf",
type: "href",
element: "href"
parameterMap().each {
input (
title: "${it.num}. ${it.title}",
description: it.descr,
type: "paragraph",
element: "paragraph"
input (
title: null,
description: "Default: $it.def" ,
type: it.type,
options: it.options,
range: (it.min != null && it.max != null) ? "${it.min}..${it.max}" : null,
defaultValue: it.def,
required: false
input ( name: "logging", title: "Logging", type: "boolean", required: false )
//UI and tile functions
private getPrefsFor(String name) {
parameterMap().findAll( {it.key.contains(name)} ).each {
input (
type: it.type,
required: false
def on() {
encap(zwave.basicV1.basicSet(value: 255))
def off() {
encap(zwave.basicV1.basicSet(value: 0))
def refresh() {
def cmds = []
cmds << zwave.switchBinaryV1.switchBinaryGet()
encapSequence(cmds,1000)
def ping() {
log.debug "ping()"
refresh()
def installed(){
log.debug "installed()"
sendEvent(name: "checkInterval", value: 1920, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
response(refresh())
//Configuration and synchronization
def updated() {
if ( state.lastUpdated && (now() - state.lastUpdated) < 500 ) return
logging("Executing updated()","info")
state.lastUpdated = now()
syncStart()
private syncStart() {
boolean syncNeeded = false
Integer settingValue = null
if(settings."$it.key" != null) {
settingValue = settings."$it.key" as Integer
if (state."$it.key" == null) { state."$it.key" = [value: null, state: "synced"] }
if (state."$it.key".value != settingValue || state."$it.key".state != "synced" ) {
state."$it.key".value = settingValue
state."$it.key".state = "notSynced"
syncNeeded = true
if ( syncNeeded ) {
logging("sync needed.", "info")
syncNext()
private syncNext() {
logging("Executing syncNext()","info")
def cmds = []
for ( param in parameterMap() ) {
if ( state."$param.key"?.value != null && state."$param.key"?.state in ["notSynced","inProgress"] ) {
multiStatusEvent("Sync in progress. (param: ${param.num})", true)
state."$param.key"?.state = "inProgress"
cmds << response(encap(zwave.configurationV2.configurationSet(configurationValue: intToParam(state."$param.key".value, param.size), parameterNumber: param.num, size: param.size)))
cmds << response(encap(zwave.configurationV2.configurationGet(parameterNumber: param.num)))
break
if (cmds) {
runIn(10, "syncCheck")
sendHubCommand(cmds,1000)
} else {
runIn(1, "syncCheck")
def syncCheck() {
logging("Executing syncCheck()","info")
def failed = []
def incorrect = []
def notSynced = []
if (state."$it.key"?.state == "incorrect" ) {
incorrect << it
} else if ( state."$it.key"?.state == "failed" ) {
failed << it
} else if ( state."$it.key"?.state in ["inProgress","notSynced"] ) {
notSynced << it
if (failed) {
multiStatusEvent("Sync failed! Verify parameter: ${failed[0].num}", true, true)
} else if (incorrect) {
multiStatusEvent("Sync mismatch! Verify parameter: ${incorrect[0].num}", true, true)
} else if (notSynced) {
multiStatusEvent("Sync incomplete! Open settings and tap Done to try again.", true, true)
} else {
if (device.currentValue("multiStatus")?.contains("Sync")) { multiStatusEvent("Sync OK.", true, true) }
private multiStatusEvent(String statusValue, boolean force = false, boolean display = false) {
if (!device.currentValue("multiStatus")?.contains("Sync") || device.currentValue("multiStatus") == "Sync OK." || force) {
sendEvent(name: "multiStatus", value: statusValue, descriptionText: statusValue, displayed: display)
//event handlers related to configuration and sync
def zwaveEvent(physicalgraph.zwave.commands.configurationv2.ConfigurationReport cmd) {
def paramKey = parameterMap().find( {it.num == cmd.parameterNumber } ).key
logging("Parameter ${paramKey} value is ${cmd.scaledConfigurationValue} expected " + state."$paramKey".value, "info")
state."$paramKey".state = (state."$paramKey".value == cmd.scaledConfigurationValue) ? "synced" : "incorrect"
syncNext()
def zwaveEvent(physicalgraph.zwave.commands.applicationstatusv1.ApplicationRejectedRequest cmd) {
logging("rejected request!","warn")
if ( state."$param.key"?.state == "inProgress" ) {
state."$param.key"?.state = "failed"
break
//event handlers
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
//ignore
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
logging("SwitchBinaryReport received, value: ${cmd.value} ","info")
sendEvent([name: "switch", value: (cmd.value == 0 ) ? "off": "on"])
## Z-Wave Toolkit ##
def parse(String description) {
def result = []
logging("Parsing: ${description}")
if (description.startsWith("Err 106")) {
result = createEvent(
descriptionText: "Failed to complete the network security key exchange. If you are unable to receive data from it, you must remove it from your network and add it again.",
eventType: "ALERT",
value: "failed",
displayed: true,
} else if (description == "updated") {
return null
} else {
def cmd = zwave.parse(description, cmdVersions())
if (cmd) {
logging("Parsed: ${cmd}")
zwaveEvent(cmd)
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand(cmdVersions())
if (encapsulatedCommand) {
logging("Parsed SecurityMessageEncapsulation into: ${encapsulatedCommand}")
zwaveEvent(encapsulatedCommand)
} else {
logging("Unable to extract Secure command from $cmd","warn")
def zwaveEvent(physicalgraph.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def version = cmdVersions()[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
logging("Parsed Crc16Encap into: ${encapsulatedCommand}")
} else {
logging("Unable to extract CRC16 command from $cmd","warn")
private logging(text, type = "debug") {
if (settings.logging == "true" || type == "warn") {
log."$type" "${device.displayName} - $text"
private secEncap(physicalgraph.zwave.Command cmd) {
logging("encapsulating command using Secure Encapsulation, command: $cmd","info")
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private crcEncap(physicalgraph.zwave.Command cmd) {
logging("encapsulating command using CRC16 Encapsulation, command: $cmd","info")
zwave.crc16EncapV1.crc16Encap().encapsulate(cmd).format()
private encap(physicalgraph.zwave.Command cmd, Integer ep) {
encap(multiEncap(cmd, ep))
private encap(List encapList) {
encap(encapList[0], encapList[1])
private encap(Map encapMap) {
encap(encapMap.cmd, encapMap.ep)
private encap(physicalgraph.zwave.Command cmd) {
if (zwaveInfo.zw.contains("s")) {
secEncap(cmd)
} else if (zwaveInfo.cc.contains("56")){
crcEncap(cmd)
} else {
logging("no encapsulation supported for command: $cmd","info")
cmd.format()
private encapSequence(cmds, Integer delay=250) {
delayBetween(cmds.collect{ encap(it) }, delay)
private encapSequence(cmds, Integer delay, Integer ep) {
delayBetween(cmds.collect{ encap(it, ep) }, delay)
private List intToParam(Long value, Integer size = 1) {
def result = []
size.times {
result = result.plus(0, (value & 0xFF) as Short)
value = (value >> 8)
return result
## Device Configuration ##
private Map cmdVersions() {
[0x25: 1, 0x27: 1,0x20: 1,0x60: 3, 0x70: 2, 0x72: 1, 0x73: 1, 0x7A: 1, 0x85: 2,0x86: 1, 0x8E: 2]
private parameterMap() {[
[key: "allOnAllOff", num: 1, size: 1, type: "enum", options: [
255 : "ALL ON active, ALL OFF active.",
0 : "ALL ON is not active ALL OFF is not active",
1 : "ALL ON is not active ALL OFF active",
2 : "ALL ON active ALL OFF is not active"
], def: "255", title: "Activate / deactivate functions ALL ON / ALL OFF. D",
desc: ""],
[key: "autoOffWithOverride", size: 1, num: 3, type: "enum", options: [
0 : "manual override disabled. After single button push the relay turns on and automatically turns off after specified time",
1 : "manual override enabled. After single button push the relay turns on and automatically turns off after specified time. Another button push turns the relay off immediately"
], def: "0", title: "Auto off relay after specified time, with the possibility of manual override",
desc: "Auto off relay after specified time, with the possibility of manual override - immediate Off after button push."],
[key: "autoOff", size: 1, num: 4, type: "Integer", def: 0, title: "Auto off", desc: "(0,1 s – 6553,5 s) Time period for auto off, in miliseconds. 0 - Auto off disabled"],
[key: "commandsToControl", size: 1, num: 6, type: "enum", options: [
0 : "commands are sent when device is turned on and off",
1 : "commands are sent when device is turned off. Enabling device does not send control commands. Double-clicking key sends 'turn on' command, dimmers memorize the last saved state (e.g. 50% brightness)",
2 : "commands are sent when device is turned off"
], def: 0, title: "Sending commands to control", desc: "Sending commands to control devices assigned to 1-st association group (key no. 1)."],
[key: "bistableKey", num: 13, size: 1, type: "enum", options: [
0: "[On / Off] device changes status on key status change",
1: "Device status depends on key status: ON when the key is ON, OFF when the key is OFF"
], def: "0", title: "Assigns bistable key status to the device status",
descr: "Assigns bistable key status to the device statusl"],
[key: "switchType", num: 14, size: 1, type: "enum", options: [
0: "momentary switch",
1: "toggle switch"
], def: "1", title: "Switch type",
descr: "Parameter defines as what type the device should treat the switch connected to the S1 terminal"],
[key: "restoreState", num: 16, size: 1, type: "enum", options: [
0: "power off after power failure",
1: "restore state"
], def: "1", title: "Restore state after power failure",
descr: "This parameter determines if the device will return to state prior to the power failure after power is restored"],
