Circumflex_sigma 0
I tried to search the forum for 'Dimmer S1' or 'Check S1', but scrolling to all the different threads, didn't let me find what i'm looking for (if it possible in the first place; don't know)
What i'm looking for is a way to check if a certain device, in my case a Dimmer, the S1 is pushed or not.
I'm trying to create a LUA scene that uses a motion sensor as a trigger to turn on a dimmer for a certain amount of time, and reset that timer every time there is a movement detected.
But in some cases, i want to push the momentary switch, what is connected to the S1, so that the timer is boosted for a much higher time.
And is the S1 is pushed again (like if i'm leaving the room) the timer is reduced again to a much lesser time, so that when the timer hits 0, the lights are turned off.
Now i looks very simple at first hand, and i have an idea how to this, but it falls or stands by the fact i don't know how to check the S1 status; if it is pushed or not.
Now i found some other fantastic LUA scenes with VD devices and all, but the code was that massive, i couldn't wrap my mind around it how it works; and i always want to know how the code works
Thanks in advance guys for looking in to this one.
Regards
David
Edited by Circumflex_sigma3 answers to this question
