Hello dear forum
Please help me
I'm trying to get a GoGogate interface up and running.
Everything seems to work, except for the answer;)
I've created a simplified scene that shows my problem.
My thought is that it is the format that is wrong, but can't figure out how to make it work.
data should contain ["2", "0", "0"]
local ip = "192.168.0.238";
local port = 80;
local user = "admin";
local pass = "password";
local door = "1";
GGG = net.HTTPClient();
function LoginURL() return "http://" .. ip; end
function LoginData() return "/index.php?login=" .. user .. "&pass=" .. pass .. "&send-login=Sign+In"; end
function OpenCloseData() return "/isg/opendoor.php?numdoor=" .. door; end   -- .. "&status=0"
function StatusData() return "/isg/statusDoorAll.php?status1=0&status2=10&status3=10&access=1&login=" .. user; end
function httpError(err)    fibaro:debug("HTTP call error: " .. err) end
function DoFunction(resp)
    fibaro:debug( "DoFunction called, url=" .. LoginURL() .. StatusData());
    cookie = resp.headers["Cookie"];
    fibaro:debug("Cookie:" .. cookie);
    GGG:request( LoginURL() .. StatusData(),
            options =
                method = "GET",
                requestContentType = "application/json; charset=UTF-8",
                headers =
                    ["Accept"] = "text/html",
                    ["Accept-Encoding"] = "gzip, deflate",
                    ["Accept-Language"] = "da-DK,da;q=0.9,en-US;q=0.8,en;q=0.7",
                    ["Connection"] = "keep-alive",
                    ["Cookie"] = cookie,
                    ["Host"] = ip
            success = function(resp)
                fibaro:debug("Resp = " .. json.encode(resp));
                _GetDoorStatus(resp);
            end,
            error =  httpError
function _GetDoorStatus(resp)
    fibaro:debug("_GetDoorStatus Data:" .. resp.data);
    data = resp.data; -- json.encode(resp.data):sub(1);
    if (data:len() <= 0) then
        fibaro:debug("Data not valid");
        return "0";
    Status = data:sub(1);
    Status = Status:sub(0, Status:len() - 1);
    whichdoor = door - 1;
    -- status = Status:split(",")[whichdoor];
    doorStatus = Status;
    if ( doorStatus:find("0") and currentState:find("0") == 0 ) then
          SetState(door, "closed");
        currentState = "0";
    elseif ( doorStatus:find("2") and currentState:find("2") == 0 ) then
          SetState(door, "open");
        currentState = "2";
    return currentState;
function SetState(_door, state)
    fibaro:debug( "Door ${door} changed status to ${state}" );
    -- fibaro:call(_VDId,"setProperty","ui.lblDoor" .. _door .. ".value",state);
GGG:request( LoginURL() .. LoginData(),
        options =
            method = "POST",
            headers =
                ["Accept"] = "text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3",
                ["Cache-Control"] = "max-age=0",
                ["Content-Type"] = "application/x-www-form-urlencoded",
                ["Host"] = ip,
                ["Origin"] = LoginURL(),
                ["Referer"] = LoginURL() .. "index.php",
                ["Upgrade-Insecure-Requests"] = "1"
            fibaro:debug("success");
            fibaro:debug(json.encode(resp.headers));
            cookie = resp.headers["Set-Cookie"];
            cookie = cookie:sub(1,cookie:find(";")-1);
            resp.headers["Cookie"] = cookie;
            DoFunction(resp);
        end,
        error =  httpError
Edited by [email protected]
