Anyone using the newer version of the Fibaro RGBW controller.
It has so many bugs!!!
I can't set the colour from a scene or set individual outputs like I did in the old -441 version.
I can from the PC app.
Anyone have the same problem.
Edited by CypressOaks
Update
    Re the new RGBW.
    I've now managed to control the colour from a scene.
    The problem now is:
    I turn on the lights
    I can then turn it on or off from the toggle switchs connected to In1,2,3,4.
    But if I turn it off from the app, the toggle switches don't turn it on again!!
    I've tried every configuration!!
    I have a problem with the lack of a button to add a light program. I don’t understand how to add my program.
    On 12/15/2019 at 1:20 PM, CypressOaks said:
    Re the new RGBW.
    The problem now is:
    If you do not turn it off, but reduce the brightness to 0 in the app, then the button will turn on the light.
    • 3 months later...
    Hi
    I have the same problem with the switch not operating if in the off position, this works with my older rgbw controller.
    Its true if left in the on position and the brightness down the switch operates but this does not work with Alexa . I have also noticed there`s no firmware update button ect. ?
    Has anyone figured out how to operate this with both the switch and remote operation please?
    Thanks in advance
    I have the same problem. Turn off it off from the app and you can never turn it on again from the momentary switch!
    also no firmware update.
    I noticed when I was adding it in HC2 (4.580) , I got a few "application rejected request"
    • 3 months later...
    same problem here. Is there any update on this? Like this, the rbgw-442 is almost unusable :(
    • 7 months later...
    same for me,
    I was using it to control lights (led stripe) in my Acquariu, to simulate sunrise, sunset, night using a scene controlled by FTBE (Sankotronic), After few months it does not work any more: it does not reacts to commands to any type of command (Scene, Software or Local Switch).
    same for me,
    I was using it to control lights (led stripe) in my Acquariun
    On 2/14/2021 at 6:41 PM, Giovanni_Genoa said:
    same for me,
     Hi to all,
    Case Solved,,,,
    Accidentally my Wife gave voice command to Google Home to switch-off everything, ang Google placed to OFF also the Slave xxx.1 (sse attached picture), which was hided in the system. I restored it with brightness to maximum and switch to ON, the lights are connected on channel 1 (RED) and are controlled ON/OFF using a scene as well as a local switch.
    /monthly_2021_02/image.png.57d0e1b5756fd4823f83ef50f6b760b3.png" />
