killer8 0
My dad got a light with 3 inputs: live, neutral and dimmer. There are 4 options to connect and the light is working a bit now(after an electrician has installed it).
However it's not working fine. We use a Fibaro switch (FGS-212).
When pressing the switch now the light is not turning on and off but starting to dim till you press the switch again.
So based on the manual(which i found online, attached to the attachments) it seems the switch is connected to the dimming input and the live and neutral inputs are permanently connected.
What we would like:
What is the recommended way to connect this light to Fibaro? I thought about the following but maybe there are better solutions
What would be the best solution to have total control from Fibaro over this light?
