fauxir 0
Good morning gents, I wrote this piece of code a few days ago for my heating system. The scene will set the radiators valve to 10 C (Danfoss Living Connect) and after 4 days, enough time to let the home cool down it will check if temperature is above 18 C. If yes everything is ok, if not it will wake up the Fibaro double switch that controls the boiler heating demand wait 5 seconds and turn off the Fibaro double switch, turn off the heating scene(Dave Harrison heating scene). Once that is done a popup will show up to give me some feedback.
Still, there is something that I don't get quite right, the valve setpoint doesn't seem to go at the desired set point.
The second thing that I'm not sure of is if the scene that modifies the set point of the valve can be affected by the heating schedule.
Any advice?
