Pulling a Neutral for Single/Double switch
Zaid_Evo
I have switch box with Live wire only and I need to pull a Neutral wire to use it with Fibaro single/double switch to control a light source. The Neutral for light source is coming directly from the main electrical panel and it is difficult to pull it to the switch box. Under this switch box I have an electrical plug which may be connected to a different breaker. My question is: can I pull a Neutral wire from this wall plug to the switch box and use it to install Fibaro switches?
Thanks!
You shouldn’t especially if you have in in different residual current circuit breaker.
Also neutral from plugs have different thickness from lights
