Hello!
I really need some advice.
Situation: I arm the motion sensors and door / window sensors. When sensors are triggered, 4-6 light sources blink and a siren starts to work. The siren is very loud. To turn off the mode, i need to press the button. Everything is simple and clear. But ...
We push the button, but nothing happens. Although a couple of minutes ago, when there were only 2 light sources, everything worked correctly. I see that when I pressed the button, the devices were disarmed, but the light is still blinking and the siren is working. After 5 minutes, everything stopped by itself.
Due to the delay of the z-wave signal, as I understand it, the controller collects a pool of commands that will then be executed. Can we fix this problem somehow?
For example, clear the command pool or not save the selected commands at all.
I will be grateful for the help.
Thanks in advance!
