Light indicator is not showing on Fibaro app
Abdulla
I installed new single switch and if I run it manually from hardware switch it will not show on in the app as on. Moreover i cannot turn device on if I turned it off from hardware.
Do you think it is because of wrong wiring?
Check local protection option in FIBARO UI
  • Thanks mate for your help
    I try but didn’t work. I guess is wiring problem. As a matter of fact some devices in my home are just working perfect
    Edited by Abdulla
