Flood Sensor firmware update cause battery drain issue
upgrading Flood sensor from version: 3.3 to 3.4 fail and drain 1/4 of battery.
The result is that after 2 attempts, I have to change the battery and I'm yet with old version firmare.
Any workaround?
Cheers,
Cesare
  • 3 years later...
Same issue.
I tried to open a new discussion on this topic but nobody answered.
Does one of you succeeded in updating his flood sensor ????
Hello again,
UP !
is it possible to have an explanation/answer/tuto/ ......... whatever you want to have some help here ?
Sorry a newbie not really an expert in software.
Just want something that work without spending hours.
  • 1 month later...
One potential workaround to try is to first fully charge the battery before attempting the upgrade again, as a low battery level may have contributed to the upgrade failure and subsequent battery drain.
