Baphomet 2
Hello all,
I am troubleshooting since some weeks an issue of the integration between HC2 and Philips Hue.
Problem Description:
- No function between HC2 and Philips Hue is working - so I cannot control any light function anymore through HC2 no scene is working, neither directly out of HC2 or using a fibaro walli switch
- All Hue functions are working directly with the Hue APP (without Fibaro)
- Fibaro HC2 shows that Hue Plugin is active - so there is a connection - it also shows "found lights" - I am used in case of a connectivity issue it shows here a connection error
- both systems are in the same l2 subnet, even attached on the same switch - from my home pc I can confirm that I can reach both devices
- there was no change by myself neither to HC2 nor to Hue - I had a working setup and 1 day later the functionality was gone!
- IPs are set to static, so also there no change...
- Restart of Hue and HC2 without any effect
Fibaro HC 2 running 4.560
As I am willing investing further into the Fibaro equipment I would first like to see that the existing environment is running in a stable condition... Therefore requesting some help..
For my perspective I cannot troubleshoot the issue further - but so far I cannot validate why the integration is not working..
Edited by Baphomet9 answers to this question
